Reply
Highlighted
I lost my phone and needs a replacement sim
Highlighted
Re: I lost my phone and needs a replacement sim
Order a SIM card online or buy one at a local store
Click on point #2 to get started: https://www.publicmobile.ca/en/bc/get-started
Meanwhile if you haven't already done so, you should logon Self Serve to report your phone as lost/stolen.
Once you have your new phone and SIM card, log back to report as found and change/update your SIM number.
Highlighted
GR
@nerialli  is there a Walmart or London drugs or wow mobile shop around you that you can go get a Sim card?   If so  after getting a Sim card just log in your self serve account and click on change Sim and enter the new Sim card number
Highlighted
I can purchase the sim at Walmart but im not sure about the self serve, I had an account a few years ago but don't remember the details.
Highlighted
When you setup a new account/phone# then you would need a different email address for the self serve account.
Highlighted
I believe OP just wants to replace SIM and phone, but actually keep his PM account and phone number.
Highlighted
If you know the email, try https://selfserve.publicmobile.ca/forgot-password/
If you don't know the email, you'll need to contact Moderator team. Click on the green Question Mark (at bottom right) to get started.
Highlighted
@nerialliWhen did you last use your SIM with your account? you said you had an account do you mean you don't currently have one? If it had been more than 90 days then the account is gone and all credits that might be on it will be forfeited. If that's the case you have to start with a different email and get a new phone number.
Highlighted
@nerialli was your phone still active (in service) when you lost it?
If you did not have a plan with PM for more than 89 days, then your old phone number is gone and you will need to signup as a new customer.
Highlighted
I used my account a long time ago. Is there a customer service number I can contact after I buy a new sim?
