Reply
Triguy
Re: I forgot my security question
Here’s when and how to contact the Moderator Team:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work
raheelmortgage
hi
JoyLuck
@raheelmortgage wrote:
hi
Hi, do you need any assistance?
z10user4
hi
Hi. Since you found this thread with the subject line...you'll need to contact the moderators.
RosieR
hi
Hi @raheelmortgage did you also forget your security question?  If yes, contact the moderators for help using the links already provided above.
Uddinjaved
Hello i am having issue with my  self serve its been a while i wanted to add some data to my plan and cant access my account i do not remember my security question answer. can someone help me asap because i really need to add Data right now
dabr
@Uddinjaved   If you have a registered CC on account and know your four digit account PIN, then you should be able to purchase (never done it so not 100% sure and someone will correct if wrong),by dialing 611.  Edit:  just tried 611 and you can purchase an add-on but need your 4 digit PIN.
Otherwise you need to contact moderators for a password reset and then can also reset your security question once you're in your account.
Click this link to submit a ticket to moderators via chatbot and follow prompts: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Second option if unable to submit a ticket is to private message Moderator_Team here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
