I cant log in my account
lindapon
kerago
Try to reset your password using your email address. Should work. If doesn't work just try to do it from other browser. Good luck!
cellphoneuser1
@lindapon Try the forgot password option. If you just activated, try to create self serve account.  https://selfserve.publicmobile.ca/self-registration/
GinYVR
@lindaponDid you activate at a store? or did you just forget your credentials? More details will definiltely help us help you figure what's wrong!
