Reply
Highlighted
How to swap number between two accounts
I would like to swap my number with my wifes account, both are on public mobile, how can I do this without loosing the number or plans?
Accepted Solutions
Highlighted
Re: How to swap number between two accounts
@keith00  Porting a number between two public mobile accounts is not allowed. What you are asking cannot be done. The only way would be to port out to another provider and then back in but your account will close when you setup the port out.
All Replies
Highlighted
A mod if any would be the only ones that would be able to do this. Other then that as soon as you ported 1 number i would asume that account would close.
Highlighted
Swap sims. And update accounts accordingly.
Highlighted
Highlighted
You may have to contact PM directly
Highlighted
That won't work because they won't do it.
Highlighted
I'm trying to figure out how to save legacy plan but port the existing number out.   I've read in the community where someone did this but cannot find it.
Highlighted
@keith00Pretty sure you cannot do it any more. They closed the loop hole a long time ago.
Highlighted
Sorry, but you can't. When you port out, the Public Mobile account closes.
Highlighted
 Apparently that used to be facilitated with the help of moderators, unfortunately, for you that has been discontinued, so you will not be able to do it as already mentioned by everyone.
