10-20-2019 07:14 PM - edited 01-05-2022 07:39 AM
Wanting to change mobile number badly, and looking for number starts with 647 or 416 if possible.
apparantly I have only seen 437 for Toronto at this moment.
does anyone know how often do they release new numbers ?
any chances getting this old but gold area code numbers??
thank u in advanced
10-20-2019 07:19 PM
Such a great news ! Thank u so much
one more question
do you know normally what time
10-20-2019 07:19 PM - edited 10-20-2019 07:20 PM
@saiii wrote:Wanting to change mobile number badly, and looking for number starts with 647 or 416 if possible.
thank u in advanced
Keep checking but there's no guarantees. A 647 area code number is far more likely. I have never seen a 416 number in the Public Mobile number pool. You might have to port one in from another carrier.
I find that less and less people are memorizing phone numbers, so some might not see this as big of an issue as before. Also, as more people get used to newer area codes, there tends to be less confusion.
10-20-2019 07:16 PM
@saiii usually every morning early all the numbers are back in the pool! I would suggest you check tomorrow morning and see if the one you want is there
