Reply
How does one locate their user ID ?
Re: How does one locate their user ID ?
PM user ID is your email address whcih you used during activation.
If you mean your 4 digit PIN number, PM sent you couple of text messages with your PIN number.  The first text has a random number.  The second text has the PIN number supplied by you during activation.  The sender of these text messages is from 611.  If you deleted these text messages, you need to send a private message to moderator to change it.
If you don't remember which address, log into your email accounts and look for the email mesaage from Public Mobile.  If you can't figure it out, you will need to contact Moderator_Team.
In addition to our emails I think we all must have  unique user ids. I think that they consist of 5 digit numbers. For example at the end of the tring there is a number.
https://productioncommunity.publicmobile.ca/t5/forums/recentpostspage/post-type/message/category-id/...
The numbers are for Community.  Why would you need that? You can't send private message to self. Yours is 63583.  You click on your profile and it shows you in address bar.
There is no 5 digit number for self-serve account. It is your e-mail address.
@Milk
There is an account number.
No unique user id number that we have access to.  Public mobile might assign us a number, but I don't think that we will ever need to use it.
@Milk  As other have mentioned your user ID is your email. If your asking about your account number you can get that if you login into selfserve. Topr right on landing page.
That's the 5 digit number I was looking for that seemed to be hiding in plain sight!     I have added it to the following string and book marked it so that I may easily check my posts.
Ok, I guess you can do that if it is easier for you but all you have to do is click on your profile.
