How do you find the total minutes used ?
Or there is no such features, we have to calculate our own?
For the unlimited minutes plan, self-serve does not show you the total minutes used. You need to added them yourself from the usage history. Since you have unlimited minutes, you don't care how much minutes you have used since renewal.
But the fixed number of minutes plan, self-serve shows you the total number of minutes used. e.g. 5 / 50MIN
Even its on unlimited, I still want to know.
Its alright. This wont show up on selfserve in future .
@MoreYummy yeah that bothered me a bit when I first moved to PM in the fall of 2015. I was used to tracking my minutes on my old plan at Telus and it was hard to give up the habit. But I adjusted and realized it really didn't matter when the bucket is limitless.
I would like to know the answer to this question as well.
I have the 100 minutes and so far it is done manually.
Sure there is a way that is easier - help anyone please
@Kered13 wrote:I would like to know the answer to this question as well.
I haven't looked but I imagine there are apps to do your own tracking of minutes.
The best bet is to get the $5 add-on as your overage bucket of minutes and not worry about it if you happen to go over your 100 minutes on occasion.
So other than the overview page counter...
Please log into your account at selfserve.publicmobile.ca . The number of minutes remaining will out of the 100 will be shown under the Data and Add-ons part of the page. Subtracting the number of minutes remaining from the 100 minutes will tell you how many you have used.
