02-26-2019 12:55 PM - edited 01-05-2022 03:30 AM
02-26-2019 02:55 PM
@Maaqtusiis65 , Facebook Messenger has nothing to do with Public Mobile.
Go to your phone's app store to add the app.
02-26-2019 02:21 PM
Thank you for all the info. I will try these.
Was trying to add fb messenger
02-26-2019 02:10 PM
If you are talking about your Public Mobile Self Serve account and you cannot go past the email stage, please try to clear your browsing history and cookies before trying again.
If the problem is with a different application please do specify exactly which application it is.
Thanks!
Eddy
02-26-2019 01:14 PM
Hi there!
Can you be more specific: what is the app you are trying to add?
02-26-2019 01:13 PM
@Maaqtusiis65 You may need to contact a moderator.
02-26-2019 01:12 PM - edited 02-26-2019 01:13 PM
You can verify your email in the first email that public mobile have send to you @Maaqtusiis65 when you activated. Can you still call and text or not?
02-26-2019 01:11 PM
I have been putting in email address and just won't go past there. Says incorrect and that is correct address.
02-26-2019 01:09 PM
@Maaqtusiis65, if you're trying to add an add-on, if you have a card on file, you can add it via 611 on your phone, using the IVR. You will need to know your PIN to do so.
02-26-2019 01:07 PM
@Maaqtusiis65 wrote:Been using my email and pw and not working.
If you are trying to login to your self-serve account, try the "Forgot Your Password" link on the login page to reset your password. If you forgot the security question, you need to send a private message to morderator for help.
02-26-2019 12:58 PM
Hello @Maaqtusiis65
Can you give us more details of your problem? No personal information.
What's not working exactly?
