How do I find my public mobile phone number
Welder09
Where do I go  to find my public mobile phone number
7 REPLIES 7
TheGx
@Welder09 :Now that your question has been answered by the replies posted here on this thread you created, you should follow up and choose one of the above replies as your accepted solution by pressing the accepted solution button above the post that helped you most - doing so well mark this thread you created as solved and also help others who want to know how to find their phone number too.
HALIMACS
Using your device, search under your Settings, find About Phone or Phone.
It will be there.
BearFBI
@JK8 Ah there you go. That's where you can find your phone number. Odd how it's not on the overview page.
JK8
In self service choose Plan Details.
You will then see your number:
Or on your phone.
Or call someone and your number would display (unless you have chosen to hide your number for calls...which you can change).
BearFBI
@Welder09 You can login to your Selfserve account from here
https://selfserve.publicmobile.ca/
Under the overview it will show your Phone number.
EDIT: Oh wait a minute it dosent. Just call someone and see what number displays.
