How can i transfer my phone number when i sign up for Publib ?
Perocolada
14 REPLIES 14
Perocolada
yes... thanks for he reminder!
Perocolada
it work well thank you!
Perocolada
i was with videotron, everything work well 😉
iPhoneUser
@Perocolada wrote:
its  a IPHONE SE
Check here  This will tell you what carrier your phone is locked too OR if it is unlocked. You need to enter your imei number.
Also I suggest that you take a number from PM first and then later port you number. But make sure your current account is still active for the port to happen later.
mimmo
@waternlava  please do not post your reveal code in the forums. It is against the community culture.
Perocolada
its  a IPHONE SE
You should be able to port a number for an Iphone as long as it is unlocked.  What is the model ?
Perocolada
im with VIdeotron
Perocolada
well, thank you
is it possible that PUBLIC cant have IPHONE ?
Triguy
Keep in mind that you need to keep your current account open during the porting process.
Here is more info.
https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
waternlava
Go to http://activate.publicmobile.ca to activate your SIM. Fill in all the fields. You can put a referral code to get a free 10$ credit. Continue to the next page and select the second option which is for getting your number transfered to Public Mobile.
Good Luck!
Dunkgirl
@Perocolada wrote:
Its for my cellphone and pre-paid
@Dunkgirl wrote:
@Perocolada  This depends, where are you porting from? Landline or Voip or Cell phone? pre-paid or post paid?
@PerocoladaWhich company? Koodo prepaid?
Perocolada
Dunkgirl
