Reply
Highlighted
How can I renew my plan now instead of the renew date?
I already tried to do it myself in self serve by changing my plan immediately but it wont work and will keep returning me to the plan page with the same renewal date. any solutions?
Accepted Solutions
Highlighted
Re: How can I change my plan now instead of the renew date?
@lukeboy wrote:
I tried everything but nothing will work, can someone help?
@lukeboy  You need to ask PM to do it for you. To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderator Hours: Monday-Friday 8 am(Eastern) to 12 am (Eastern) and Saturday, and Sunday from 8 am(Eastern) to 10 pm (Eastern).
All Replies
Highlighted
Once you log into your account, look for Account Status.
  • Just below that there will be a button 'Change Plan'.  Click that.
  • You will then see a screen that says 'Change My Base Plan'.
  • You will see a list of the current plans offered.
  • Select a plan, use the radio button to the left of it.
  • Then Scroll down further.
  • At the bottom you will see two choices/buttons:
  • Change plan now      OR      Change on next renewal date
  • Select 'Change plan now', you will charged the full amount of the new plan right away, and forfeit any days left on the previous plan/30 days.
Highlighted
Go into your account at Selfserve.publicmobile.ca. Plans and Add-Ons. Change Plan. Choose the plan. Click Change plan now.
That not working?
Highlighted
You have 2 options when you click on CHANGE MY PLAN in your self serve account now or on the next renewal date. You can’t see or you can’t do it? Do you know if you change your plan now you will loose the money you gave for your current plan and your rewards will not be applied for this switch but you will have them for the next one? If it’s because you WANT a new promotional plan you can have it if you ask for a changing plan for the next renewal date even if the promo disappeared....
Highlighted
I don't believe you can manually change to the plan you are already on (if you are just trying to refresh something you are out of). Otherwise, the first reply has it worded perfectly.
Highlighted
1.  Login to your self-serve account
2.  Select "Plan and Add-ons" tab.
3.  Click the "Change Plan" button
4.  Select the plan you want
5.  Click the "change plan now" button
Please note that PM is prepaid service.  There is no refund of the unused days if you change your plan immediately.
Highlighted
@LovesToPM I done this already and it still don't work. it just takes me back to the plan page with the same renewal date. -.-
Highlighted
@lukeboy, as others have said, you have to select a different plan. You cannot select the same plan you are already on.
You can also try with a different browser such as Chrome, Safari or Firefox. Deleting cookies and incognito mode may also help.
Highlighted
@lukeboy
The website can be finicky.  Maybe logout of your account.  Wait a while and try again.  You could try a different web browser, clearing cache or incognito mode.
Highlighted
@LovesToPM okay well anyone know of any mods that are online that can renew it for me?
