How can I log out of the community?
abclilly
@abclilly wrote:
Thank you.
@abclillyNot sure why you want to log out, but another method which will also remove all traces would be to go and clear your cookies too. Even after you log out there are still cookies on your machine regarding your login.
abclilly
Thank you.
will13am
Click on your avatar on the upper right corner and you will see a menu with sign out option appear.
jordan23
hi @abclilly , you can just click at your avatar (on the top right hand of the page below "My Account") and click sign out
