04-04-2019 06:00 PM - edited 01-05-2022 04:09 AM
I try to call the different number but it said is not added to my plan I have to add but I have an unlimited call in Canada and text some other number is going through.My phone number is
Edited by computergeek541 to remove phone number
04-04-2019 07:50 PM
All my contacts in my phone I put a number 1 in front so I don't get that annoying "this number a long distance number please hang up and use number 1 before number. That fixed the problem
04-04-2019 06:07 PM
@mohamedalawy255 If adding a 1 does not help, might as well give the lost/stolen trick a shot, it seems to fix almost every problem at public mobile. Log into your self serve (my account) CLICK HERE then click “Plan and Add-on” then click “Lost/Stolen Phone” and click “Suspend Service” and click the “logout” button near your name/account balance. Wait 10 minutes. Log back and do the exact same procedure except this time click reactivate service phone found, reboot your phone. This seems to reset you sim / account and may fix your issue.
Otherwise, If it does not help, contact the moderator team to reprovision. Use this link to send a message to the moderator team.
04-04-2019 06:05 PM
@mohamedalawy255 wrote:I try to call the different number but it said is not added to my plan I have to add but I have an unlimited call in Canada and text some other number is going through.My phone number is
We are customer like you here..we don't need your phone number You can hide it ..click on the 3 dots right up in your message..
Which plan do you have?
04-04-2019 06:05 PM - edited 04-04-2019 06:06 PM
@mohamedalawy255 Hiiiiiiiiiiiii please remove your phone number, this is a public place. Try adding a 1 to the number.
04-04-2019 06:04 PM - edited 04-04-2019 06:04 PM
@mohamedalawy255 wrote:I try to call the different number but it said is not added to my plan I have to add but I have an unlimited call in Canada and text some other number is going through.My phone number is *******
Don't post your phone number this is a public forum.
Sorry you are having trouble. You might find that adding a ”1” to the beginning of your phone call dial might solve the issue. As long as you have minutes left (are not on a limited calling plan) your account may have a provisioning issues where the database of included calling numbers is corrupted. Please reach out to the moderator team and they should be able to reprovision your account. Click this to send them a message
For more information about contacting a moderator Click Here
04-04-2019 06:04 PM - edited 04-04-2019 06:05 PM
@mohamedalawy255 wrote:I try to call the different number but it said is not added to my plan I have to add but I have an unlimited call in Canada and text some other number is going through.My phone number is xxxxxxxxx
If it's a number in your contacts then it might need a 1 in front.
Is it just the one phone number? You seem to say another number works fine? Or was it the texting going through?
