Reply
Animalfc2021
Hi
We bought 4 $25 pre paid cards and 2 of them don't work
Accepted Solutions
HALIMACS
Re: Hi
Hi @Animalfc2021
If you DIDN'T purchase these at the same location (and at the same time), you should consider:
  • Payment voucher PINs are 12 numeric digits located on the receipt you receive from our retail partners.
  • The location of payment PINs vary; however, generally, it will be at the bottom or top of your receipt.
You may wish to logout, clear cache and cookies, then open incognito tab and try entering them again on the subject account you wish to add them.
If you can't them to work, contact Moderators to advise.  It might be a good idea to have all 4 of them on-hand to provide details of the 2 that WORKED and the 2 that DIDN'T WORK.
To contact a moderator, there are 2 methods:
  1. Use the ticketing system for a faster response time. Click here and type moderator assistance, then select account-related issue, then select you need a human now.  Follow the prompts to submit a ticket,  or,
  2. Send a private message to the moderator by clicking here  You’ll need to be logged into your Community account for the link to work.
All Replies
Re: Hi
@Animalfc2021  4 vouchers and 2 of them not work?  Did you buy them together from the same place?  did you just buy them today?  Some vouchers need 24 hours for it to activate on the backend.  Not sure if it is because of that
villellamcmeans
Re: Hi
@Animalfc2021 :Where you buy them? They should all work right away if from London Drugs or Shoppers Drug Mart.
Re: Hi
@Animalfc2021 can you try loading them by either calling 611 or through your self serve?
HALIMACS
Re: Hi
Hi @Animalfc2021
