Reply
Help!
I took my SIM card out today and when I put it back in, it gives me a message of no sim or invalid sim. I have turned my phone off and on and nothing changes.
When I try to log in to my account it says it’s invalid and wen I try to change my password it wants to send me a text but I cannot receive it because my phone shows no sim. Please help!! I have been a customer for about 6 months and have been very happy with PM
Re: Help!
Try taking it out again, restart your phone, then put it back in. If that doesn't work try taping the sim down with a small piece of tape to improve the connection. If your phone is a dual SIM try the other slot.
Is there any chance you damaged the SIM when you took it out?
Re: Help!
I'm sorry for you @AllanaHawkes
why did you take it out?? Is it because you had trouble with it? Are you in your renewal date???
You can write a message to the moderator for help...
https://productioncommunity.publicmobile.ca/t5/notes/composepage
and explain what happened....wait 1 or 2 days they will help youSmiley Happy
Re: Help!
Surest test for the SIM itself is to try it in another unlocked phone.
To recover access to your account, follow Lieau's suggestion to contact the moderators.
What is make/model of your phone in case someone has more specific advice.
Meanwhile, if you need to make phone calls try an application like that from fongo.com (or Hangouts). It provides free calling across Canada from wherever you are connected to wifi (or on cellular data).
>>> ALERT: I AM NOT A MODERATOR. JE NE SUIS PAS MODERATEUR.
Re: Help!
I had no trouble with it, my friend purchased a public mobile sim for his new iPad and I was just showing him how to remove and put in a sim, as he had never done it before.
Re: Help!
Can you try buffing the contacts of the SIM card with a clean cloth to remove any tarnish or fingerprints, and then re-seating in the tray and re-inserting?  On the occasional phone, this has helped.  Sometimes simply popping it out and re-inserting may also help.
Re: Help!
Also I did send a message to the moderator last night so I am hopeful that I will hear from them soon. Thanks for your reply!
Re: Help!
Be patient they will answer you @AllanaHawkes..Smiley Happy
Re: Help!
Thanks, I’ll try that!
My my phone is an iPhone, 6s
Re: Help!
@AllanaHawkes Try your friend's SIM in your phone and vice versa. I now suspect your SIM is damaged but this test will decide. As long as you have data in your plan it will work in an iPad.
