06-19-2018 11:21 AM - edited 01-04-2022 06:13 PM
My phone plan has expired and I tried 2 different credit card and it keeps being denied. I contacted my CC company and they say its not them
I need @CS_Agent to help
Erin
06-19-2018 06:23 PM
@ErinLeslie wrote:that was it
@ErinLeslie suite number strikes again! I'm glad I was able to help and you were able to add your credit card successfully. Have a great evening!
06-19-2018 05:26 PM
that was it
06-19-2018 05:18 PM
@ErinLeslie ignore any formatting suggestions on the form and type in your address *exactly* as it appears on your credit card statements--same punctuation, same capitalization, same spacing.
In particular, if you live in a condo/townhome with a unit/suite number, try leaving that field blank on the form and entering it in the regular address line box if it appears that way on your credit card statements. For example if you live in unit #123 and 555 Fake St, and the credit card statements says:
123-555 Fake St
Then enter it that way all together and leave the unit number field blank.
06-19-2018 01:14 PM
still need help with credit card ?
06-19-2018 12:29 PM
I tried that and still no luck.
this is so frustrating...
06-19-2018 12:24 PM
Not sure what browser(s) you are attempting, but I've had success with Safari on iOS devices, and Chrome on Windows and Linux boxees.
Make sure you turn off any ad blockers or other anti-malware tools. It *shouldn't* matter, but sometimes it does matter.
06-19-2018 12:11 PM
I tried a visa debit and it did not work either.
06-19-2018 12:05 PM
also, have you tried a prepaid visa or master card?
06-19-2018 12:05 PM
We had the same issue in the past. And it was a bank issue. Their security system blocking the public mobile. works fine now.
06-19-2018 11:29 AM
I tried the private browsing and it does not work
06-19-2018 11:27 AM
Please try again after clearing your browser’s cache and using incognito/private mode, or a different browser.
Still no joy? Click this: message to moderators to send a private message to the moderator's team with your phone number, PIN, and an explanation. Moderator hours are as follows: Monday to Friday, 9 am (ET) to 9 pm (ET); Saturday - Sunday 9 am (ET) - 7:30 pm (ET). The answer is usually in a few hours, but can take 24.
Meanwhile, if you need to make phone calls try an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi, or on cellular data.
