Hello. New subscriber with no data
lorvar
I just signed up for the 4.5gig 3G data plan, but my data doesn't work. It's on, but shows 0mb used. can't send or receive internet or pictures through text. I've restarted the phone. I have a Samsung s7 edge. Plan was activated yesterday.
Thank you
popping
@Acekiller wrote:
if it doesn't work, you may need to do a factory reset on your phone. if is often the case with LG phones and some others.
Make sure your APN settings are as follows:
Set up your APN
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC:
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
For LG phones, no need to do factory reset.  Just do a network reset.
Factory reset will clear everything in your phone.  After factory reset, you need to spend lots of time to setup your phone again ifyou do not have a backup.
While network reset will not touch your settings - just the network related parameters.
Acekiller
Set up your APN
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Server: Leave blank
MMSC:
MMS port: 80
MCC: 302
MNC: 220
lorvar
Thank you!
SD08
For data, make sure you have the correct APN settings:
https://apn-canada.gishan.net/en/apn/public-mobile
