Forgot my Username and password
Tomtomwalter93
I forgot my username and password to my self serve account
Joaquim-Pereira
Staliger
@Tomtomwalter93 you can contact moderators : click the "?" in lower right side of the page, type "contact moderator", and follow directions, OR send a message: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
NDesai
@Tomtomwalter93  As mentioned above, username is your email address entered when you activated. Using your email, you can reset your password using Forgot Password tool. If you are not sure which email you used, then check all your email accounts and you should've received the Welcome email from Public Mobile on the day you activated.
@Tomtomwalter93
Have you tried reseting your password?
https://selfserve.publicmobile.ca/forgot-password/
If that does not work, you will need to contact moderator to help access your self service account.
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator.  Type: Contact moderator. Follow the prompts to submit ticket.
hairbag1
Username is your email address...does that help ?
Then clik "forgot your password"
