Family Plans
Sofiasmomma
Wondering if you have any plans for two phones? Myself and my daughter each have a phone looking to bundle as one bill.
7 REPLIES 7
kselmak
Hi @Sofiasmomma
Pm has very affordable rates that already beat many family plans from competitors.
Go for autopay it will give you $4 off combined.
User referral, first time from your friend and when you open the second account, use your own, that will give you $1 off every cycle.
For each year you will get loyalty rewards up to $5 per account, that will make it eventually $10 off monthly for both of your accounts.
What plans are you thinking of getting?
Welcome to pm
Staliger
@Sofiasmomma Not at the moment, but perhaps they will be added in the future. Only PM knows. As for now, you can have separate accounts, but enable Autopay for both of them using the same Credit Card.
maximum_gato
@Sofiasmomma
There are no family plans at public mobile but you can choose plans that tailor to each of your needs.....and can be easily changed for the next 30 day cycle if those needs change. Being a prepaid service you have no worries with overages, extra billing or billl shock.. Its a great way for people to learn how to manage their data usage and their accounts without a costly lesson.
@benfatto
Posting a request for a referral code is frowned upon as explained in the recent updates to the community guidelines. As is spamming the OP which is what it would lead to..... Its best to just advise the OP to privately message a member of their choice and ask for one just like you would ask your friends or family for one.
benfatto
@Sofiasmomma  As already noted no family plans, but be sure to activate the second account using the referral code from the first.
if you need a referral code for the first account post a request and someone will oblige.
gblackma
@Sofiasmomma  there aren't any family plans here. Each account requires  a sim card and email address. Aliases allowed ie sofiasmoomma@gmail.com and Sofiasmomma+@gmail.com. Just keep them under 30 characters. Welcome to PM. Stay safe.
Here's 4 articles on activation and porting and the Refer a friend reward  if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Triguy
Unfortunately,PM does not offer family plans.  You could setup two separate accounts but pay using the same credit card.
