Does anyone else’s data useage go up when they haven’t left wifi all day?
satkinson
7 REPLIES 7
@Tony_Xu  Toggling airplane mode on and off will also reset any extraneous data counted from MMS as well
You are welcome @Tony_Xu . Be a fly on the wall here, and you will learn a lot. Welcome to PM.
@Tony_Xu wrote:
Thank you! Good to know!
Tony_Xu
@scorpio17 wrote:
Just wondering, why they didn't fix this bug?
@computergeek541 wrote:
@satkinson There is a fluctuating 5.293MB of data that shows up in selve serve that doesn't represent actual data use. Over time, that 5.293MB gets returned.
I'm not sure it _is_ a bug. One might think of it as a look ahead window. Consume 5mb and it will grab another 5mb. etc. Finish your session of consuming data and (I think) overnight it will reset back down to your actual consumption of that last window.
scorpio17
satkinson
Oh ok, awesome, thank you 🙂
