03-12-2019 12:18 AM - edited 01-05-2022 03:40 AM
Hello,
I am not able to get data working yet. I have manually entered APN settings. Phone is an Asus zenphone max plus. Done a network reset. Data Works on secondary bell sim. Still does not work with bell sim removed. Tried sim in both slot 1 and 2. Data is on with roaming enabled. Plan includes data. Phone says is compatible when search s/n and imei.
hope I’m just missing something
thanks
03-12-2019 12:52 AM
@Prw990 wrote:Hello tried with zenphone setting as well as generic android settings. Don’t know if it means anything but 4g flashes on briefly every few minutes but unable to search or download picture texts. See previous reply for exact zenphone model. I checked compatibility before switching to public mobile and seemed ok
If you used the checker on this site then it's not very reliable.
But from what I can tell from gsmarena it might work. I don't know about all the international and even US stuff for working here. Radio is radio I guess.
Can you force down to HSPA 3G to get data?
Since you didn't find your specific phone on the gishan site maybe these might work:
Watch for case and spaces.
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
03-12-2019 12:38 AM
03-12-2019 12:35 AM
Zenphone max plus M1(ZB570TL)
03-12-2019 12:30 AM - edited 03-12-2019 12:31 AM
@Anonymous wrote:Could you post the exact details of the model. There are variations of these phones.
Most posts that begin with asus zenfone max, end with disappointment for the owner.
03-12-2019 12:26 AM
@Prw990 wrote:Hello,
thanks
03-12-2019 12:23 AM
thanks
Try changing the autoconnect and manually select PM and it's APN to see if that works
03-12-2019 12:22 AM
The APN Setting need to match exactly.
Ensure you have the correct APN settings by visiting https://apn-canada.gishan.net/. Select the brand and model of your phone, scroll down the page and then select Public Mobile. After doing so, you will be provided with the exact APNs required for your phone on our network.
Have you tried your SIM card in another phone to determine whether hardware issue versus Public mobile issue?
