10-14-2018 08:46 AM - edited 01-05-2022 02:08 AM
Hi, I have the $40 4.5GB plan, but I have used more data than usual this month, I still have 2 weeks to go before plan renewal, is there anyway to add data to my plan? Can I add another $40 for 4.5GB halfway through the month? Thanks
10-14-2018 11:24 AM
Another option, if it seems feasible, would be to switch to either the $45 6GB plan, or the $50 8GB plan.
Yes, more expensive, but they do have more data available, and you can get this done right away.
NOTE, as updated in the original thread postings, these plans will not be available after midnight October 15th (late Monday night) Eastern time.
10-14-2018 09:21 AM
(similar reponse to your other post)
If you want the renew the same plan earlier, you will need to contact moderator to renew early. It takes 1-2 days for moderator to respond to requests. Faster to switch to another data plan (? larger one) immediately.
Or you can buy an additional 1 GB data add on for $30 (expensive). Unused data will roll over to next month (with the add on).
