Reply
Highlighted
Data cut off but I haven't used my monthly amount
Hello all!
I hope you can help. I only became a customer last month and am supposed to have 1 GB of data/month (1st to 1st). Yesterday, my data was cut off due to limit being reached but I've hardly used the monthly amount. My phone is showing data usage as 202 MB. I looked online at my account and don't see the data limit being reached, even including May.
I'm not impressed. I still have another phone with my Freedom plan on it (which I haven't had problems with).
Thanks.
Highlighted
Re: Data cut off but I haven't used my monthly amount
@samk13Since we are all regular users here, can you post some screen caps of your account information eg the details underneath My Plan - > Plan Details. Under My Data & Add-Ons did the data item go away? It may provide us some insight to see what we as regular users can help you with, before escalating it to the Moderators.
Data usage is usually rounded up to the nearest kb, so rouding error won't explain such descrepency.
Highlighted
@samk13
Sorry to hear about your troubles.  The PM data tracker is usually accurate.  Do you see  the 1GB add on in the My Data & Add-Ons section?  If you don't see the data add on, it means that it ran out.
You can choose Plans and Add on tab, then Usage history tab to see the detailed usuage history.
If you still feel that it is inaccurate, you can contact moderator.
Send a private message to moderator through the following link :
Highlighted
@samk13
Sam, is there a possibility that awhile ago, on your phone under Data Usage, Billing Cycle, Set Data Limit: did you set a limit?
Highlighted
I didn't set a limit
Highlighted
As mentioned, if you don't see mention of data lower down on your overview page under Data & Add-ons then you've used it all.
You would need to set up your phone just so for tracking usage.
What plan are you on and when did you renew
Highlighted
@samk13 wrote:
Hello all!
Thanks.
Have you confirmed that you're on the right plan and that you're allocated 1 GB of data?
Example: The $15 plan with auto-pay only provides 250 MB of data and not 1 GB.  I'm thinking you might me on this plan.
Highlighted
My plan is $25/30 days, 500 MB+500 MB at 3G
Highlighted
@samk13  Here is a good article that provides tips on how to manage your data usage.
Highlighted
I have that plan  in order to keep under the 1gb I had to go into settings and turn off all auto updates so they would only update on wifi it helped me alot also stay away from video intensive apps  have had no problem since
