Reply
Highlighted
Data Top Up
Pls how do I top up my data
Accepted Solutions
Highlighted
Re: Data Top Up
@DammyYou can purchase a data Add on. Follow @srlawren 's tutorial here.
All Replies
Highlighted
Re: Data Top Up
Look up til you see Plans. Click it, then scroll down to Add-ons. 1GB data is $30
Highlighted
Re: Data Top Up
Highlighted
Re: Data Top Up
@Dammyyou have 3 options
1) buy a data addon  1gb for $30
2) top up account and do an early renewal can take up to 48 hours for mods to reply.
3) do an immediate plan change to a plan with more data
options 2 and 3 require you to basicly forfit the remianing time of your current plan. (ie restart a new plan cycle), butthese are usually more cost effective $/gb vs the data addon
Highlighted
Re: Data Top Up
Go into your self serve account and look for the ADD ON section
Highlighted
Re: Data Top Up
Many thanks. I'd rather change plan than a top up as advised
Highlighted
Re: Data Top Up
@Dammy
Other options include renewing your plan earlier, but you will need to contact moderator (expect 1-2 days wait) or change plan immediately to another data plan.  You will lose remaining allottment of your original plan.  No pro-rated plans with Public mobile.
Highlighted
Re: Data Top Up
SMART move it's alot cheaper that way and economical
Highlighted
Re: Data Top Up
Pls, how long will the plan be effective?
Highlighted
Re: Data Top Up
30 days
