07-17-2018 11:28 PM - edited 01-04-2022 06:28 PM
Hi,
This would be my first bill and as I was seeing my credit card transaction history, I was shocked to see Public mobile charging 60.6 dollars instead of the 38 dollars. I am unable to find any connection to the 60 dollars. Nothing adds up. I am a student living on mininmal income. This plagues me!
07-19-2018 04:27 AM
@jesvinsjoseph They should able to fix this easily.
This kind of error happens once a while. Too bad, we need to catch them.
07-18-2018 10:51 PM
Thanks everyone, you guys are very supportive! This was PC mobile - President's choice making that debit. I ported my number before my billing cycle and they still charged for the month.
I believed that once you port the number, it automatically cancels your account from your previous carrier. Looks like these guys did not. I am not sure what to do. I will have to call them.
My bad! The names are pretty confusing.
07-18-2018 02:38 AM - edited 07-18-2018 02:39 AM
@SD08 wrote:Edit: I see that an Oracle (thanks @NDesai) has helpfully removed it from your post
Right!
Make sure you edit your post so no one knows.
07-18-2018 02:09 AM - edited 07-18-2018 02:53 AM
In the meantime, while you get this sorted out...
That 16-digit number starting with 4537 in your 2nd pic looks specifically like a Visa credit card number. I'd advise you to remove or edit that number from the photo, since this is a public forum visible to anyone. Even though CC transactions usually require more info, I say better safe than sorry.
Edit: I see that an Oracle (thanks @NDesai) has helpfully removed it from your post.
07-18-2018 12:01 AM - edited 07-18-2018 12:04 AM
The transactions listed in your screenshot are from June. Your credit card transaction is for July (and less than 30 days from the previous payment). Maybe your payment history for July will update soon and you can see what the charge is for.
Did you make any changes to your plan today?
07-17-2018 11:43 PM
With potential billing errors, likely need to PM one of the moderators. They are usually very helpful and likely can correct any errors.
Here is instructions to contact moderator:
