Changing plan can't get into selfserve
Joedh
Trying to change plan can't get into selfserve won't let me register
@Joedh, it sounds like possibly, you haven't created a self-serve account yet, and I'm betting you ish to change a plan as you're now without service?  Is this correct?
If yes, you'll need to contact the Moderator_Team by private message.
If you do have service, are you not able to receive the SMS from the authorization service?
LovesToPM
Clear your browser cache and retry using incognito mode.
If no improvement, try with a different browser on your computer.
popping
Re-start your browser and start over using this link to create your self-serve account.
https://selfserve.publicmobile.ca/self-registration/
You need your PM phone to received a 6 digits code and the answer to your sceurity question.
NDesai
@Joedh Try using private/incognito browsing more. It'll work eventually.
geopublic
@Joedh  Are you receiving an error or is it too slow. If it's still spinning just need to wait and eventually it will let you in.
