09-22-2020 12:46 PM - edited 01-05-2022 01:18 PM
Hello,
I just upgrade my plan a couple of days ago from the $25/mth plan to the $35/mth plan which included 1.5gb and another 500mb on AutoPay, however, when I signed into my account, it's only showing 1.5gb of data, nothing indicates the extra 500mb. I am signed up with AutoPay.
My previous plan had 500mb plus another 500mb with Autopay and it showed up on my account as 1gb, but since I've changed my plan, it's only showing 1.5gb.
Help plz...Tks
09-23-2020 12:19 PM
09-23-2020 12:13 PM
I have the same issue
09-22-2020 02:51 PM
@darlicious @Anonymous
Thanks for the replies and help. I guess confusing is the normal at PM. Have no major complaints with them, but when I noticed this on my account, it made me wonder, but it looks like it should be be ok.
Thanks again!
09-22-2020 02:21 PM
So you do have 2gb of data its just the way pm displays your plan data. Each gb of data has 1024mb. 2×1024=2048 which shows in your data counter. If you buy data add ons it displays the same way. For example if you bought 3 x 1gb data addons= 3072mb the line will look like this:
1 GB Data add on at 3G speed..........0/3072
A little confusing but that's pm.
09-22-2020 02:19 PM
@turtlegurl wrote:Right now it shows 26.83/2048.
It's kind of confusing because my old $25 plan was 500mb + 500mb, but in my plan details, it showed 1gb of data, not the 500+500.
My parents both have the $40 plan of 4.5gb data plus 500mb with autopay, but when they sign in, it just shows 5gb of data.
There are all kinds of oddities around here. You have the 2gb. You're good.
09-22-2020 02:15 PM
09-22-2020 12:57 PM
What does the MB say at the end of the line in your overview page? Does it look like this?
1.5 GB data at 3G Speed........................ 0/2048
09-22-2020 12:50 PM
Here’s when and how to contact the Moderator Team:
