Reply
Change phone number
How do I change my phone number?
Re: Change phone number
To change your phone number: sign in to Self-Serve, select ‘Change Number' under 'My Profile' on the Overview page. Here, you can choose to select a new phone number or to transfer a wireless or wireline number from another provider.  Also you can only change your phone number once every 30 days.
1. Log into your PM account.
2. Click the Plan and Add-on tab.
3. Click change phone number.
You can change your number every 30 days I believe.
@EKHP
Here is a screenshot of the change number section:
It's all done through your Self-serve account.
You are able to change to have a new number once every 30 days.
If you are porting over a number, you can do this as often as needed.
Latest suggestion... When changing to a new number, it is recommended to google search it first (to check it's history) before accepting the number and making it yours.
