10-11-2019 06:38 PM - edited 01-05-2022 07:31 AM
Is changing your phone number free?
Is it true you can change it once every billing cycle?
Each time I try to change my number it only offers a certain area code of numbers not like when I signed up, how do I get more area code variations?
Thanks.
10-12-2019 12:02 AM
@QRWN wrote:Is changing your phone number free?
Thanks.
Only one change per 30 days but there won't be much choice on area code. New area codes are used when they are running low on phone numbers. It's important to take a phone number for the correct city. That is more important than area code.
10-11-2019 06:50 PM
Yes.
Yes.
Just keep changing area codes back and forth and a new numbers will be presented yo the pool. Also best to check early morning hours EDT because that is when the add new numbers to the pool.
10-11-2019 06:43 PM
Thanks.
Yrs i noticed that too
You can't pick last 4 digits either
I've read that some people did get help with their numbers by moderators. Maybe if you have a particular request you could ask them directly.
10-11-2019 06:40 PM
@QRWN yes you can for free once a month but like you said you only have a limited number of numbers to pick from when it's a number change compared to a new activation picking a new number
