Change of number
marvy
I have just changed my phone number may I reverse this and go back to my old number back
surreyboz
Once you change your Number, Your old number goes into a pool of numbers where its held for 90 Days. After 90 days it goes back into circulation with the Provider that the number belongs to. Eg.  So say it was a Bell number it will go to Bells Pool of numbers, if it were Rogers it will go to Rogers etc.
Dogbert
The self-serve options won't be able to help, but maybe a mod can (link).
Be sure to include the following:
- your name
- your account number
- your current phone number
- your desired phone number
Good Luck!
@marvy , these two threads have been merged to try to keep things organized.  It should also be easier to get your answers this way as you won't need to check in 2 different places.
@marvy No, your old number is gone and you won't be able to change it again for 30 days.
marvy
I have just changed my phone number may I reverse this and go back to my old number?
hycm53
I’m not sure you can. You can change phone number after 30 days if I’m not wrong.
