Cant reset password and locked out
Trev2019
I cant access my account it says ask public for help. Can anybody help me
Leeannehorton10
I've been having the same problem
sonician
I've been trying to reset my password for two days, but the email never arrives.
@Trev2019 wrote:
Tried doesnt work
If the password reset function does not work for you and it seems to fail some customers also, contact the moderator team to complete the password reset.  The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.
Trev2019
Tried doesnt work
Dunkman
@Trev2019
If the reset function is not working, you will need to contact moderator.
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator.  Type: Contact moderator. Follow the prompts to submit ticket.
