Reply
Highlighted
Cannot review plan details
I've been with Public Mobile for a couple of years now, and about 3 months ago I noticed I couldn't access my Plan Details.  It wasn't important enough then to follow up, but now I really do what to review my plan, but can't.
I've tried:
-Logging in and out
-Clearing caches
-Different browsers
-Different computers
-Different phones
I simply cannot preview my plan details regardless, I get the message:
Oh no!
It looks like something went wrong, but don’t panic.
Log out and then log back in again to continue. Or return to the Login Page
Highlighted
Re: Cannot review plan details
Submit a ticket to a moderator by clicking on the question mark on the bottom right.
Highlighted
I've tried:
-Logging in and out
-Clearing caches
-Different browsers
-Different phones
Oh no!
@TechCowboy  Are you using a computer or your phone? Try it on another computer if it works then.....
Highlighted
@geopublic wrote:
I've tried:
-Logging in and out
-Clearing caches
-Different browsers
-Different phones
Oh no!
I would also make sure your browser is up to date and try using Chrome Incognito mode.
Highlighted
I moved from BC to PEI, and but I originally created the account in BC
I was setting my region to PEI
SOLUTION:
You must set your region to the area where you created the account.
Highlighted
SOLUTION:
Not quite correct. If you login to self serve and click Change Number you may choose a number from anywhere in Canada.
>>> ALERT: I am not a moderator. Je ne suis pas un moderateur.
Highlighted
Luddite, your comment has nothing to do with the issue at hand. I didn't change my number, I still have a BC number even though I moved to PEI. In order to see your plan details, I must set it to the region that created the account or it produces an error.
