Reply
Cannot receive incoming calls
I switched to public mobile yesterday and brought my own phone with me (May 14) and since then I am unable to receive incoming calls.  Incoming calls are going straight to voicemail
Outgoing calls, text and data are working.
I have an Andriod device ( Samsung)
Can anyone help or direct me please?
Thank you :-)
Re: Cannot receive incoming calls
@Carterseabright As you just started with yesterday , did you request a port-in of your number?It sounds like you may have a port in progress.  They can usually take between 5 min to 2 hours to complete.
If you wait longer than 12 hours I would ask the moderators to look at it.  Send them a private message , provide them with your name, account number, and an explanation of the issue and they will be able to look into the matter for you.
Thank you :-)
@Carterseabright  Are incoming calls going to your Public Mobile Voicemail?
Thank you, I have sent a private message to the mod, I am sure I will hear back soon.
No they are not going to the public mobile voicemail.  I must have made a mistake when setting up the new account I guess :-(  I have sent a private message and I hope to hear back soon.  Thank you for responding!
@Carterseabright  If you requested to port (transfer) your number from your previous provider then the calls are still going to the old providers VM. This is normal and it means that the port is not 100% complete. If that is the case then you will receive a text from Public Mobile notifying you when the port has been completed. At that point you should start to receive incoming calls.
Did you port a number over?
Aside from filling out the required info (including telephone number, previous service provider ect...) when going through the sign up process, I haven't done anything else.  Maybe I didn't complete all steps?  Although I am sure i did.
@Carterseabright  Sounds like you did everything right. So you did port your number. Ports can take up to 5 hours to complete. If it's still an issue after that it's possible that your port might be stuck and will require PM intervention. To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderator Hours: Monday-Friday 8 am(Eastern) to 12 am (Eastern) and Saturday, and Sunday from 8 am(Eastern) to 10 pm (Eastern).
Thank you,
I just received a text saying my transfer request was completed, so in my case it took about about 24 hours.  I appreciate everyone's quick response to help and will pay it forward to others if I can!
