Cancel Plan: Unable to locate PIN number
ryanyu_3
Hi I need help!
I am trying to cancel my plan and remove auto-pay but it asks for a pin number which I don't have. Is there anything else I can do to validate myself so I can make this cancellation?
Hopefully customer will let us know how it was resolved.
@mimmo wrote:
@will13am from what I recall pin number is needed when changing via 611, not srlfserve
Yeah, I got side tracked by the suggestion to contact via 611 which had me thinking that the self serve is the one needing the PIN code.
mimmo
will13am
I have not done any auto pay changes in a long while.  Is the PIN code thing a new addition to the self serve?  I don't recall any self serve function requiring a PIN code authorization.  You'd think the login should sufficient.
mimmo
Log into self-serve and remove that way
hairbag1
Try calling *611. Option to remove auto-pay.
