Reply
Can't send or receive MMS on Samsung S7: Please help! :)
I can't seem to send or recieve MMS on my Samsung S7.
I've set up all the VPN settings according to the following:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Leave blank
APN type: Leave blank
Mobile data otherwise works and I have it turned on.
I'm really stumped as to what the issue might be. I haven't found answers elsewhere on the fourm. If anyone has a semblance please advise me!
Thanks!
Tags (3)
Re: Can't send or receive MMS on Samsung S7: Please help! :)
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Server: Leave blank
MMS port: 80
MCC: 302
MNC: 220
Thanks!
@AndrasL  Have you enabled MMS within your Message app? Also can you post a screenshot of your APN settings. Why is APN Type not set?
@AndrasL , I would try setting your APN type to:
default,mms
(note, no space after the comma)
