Can't login my account
sarahhaniya
Hi,
I haven't been able to login my account. Everytime I enter the password, it says it's wrong and when I try to reset the password it doesn't send me the link to reset. Please help asap!!!
8 REPLIES 8
@BensonK89 wrote:
I'm having the same issues; i just changed and topped up my plan about a month ago and i tried to login to my account to check the status but it says my password is incorrect; when i hit the "forgot my password" button and input my email address it gives me an error message saying my account login is disabled. How can this be fixed?
Since the password reset option isn't working, you'll need to open a ticket through https://publicmobile.ca.ada.support/chat/
BensonK89
sarahhaniya
@GR Thank you so much!!!
@sarahhaniya    contact them by clicking here!
Also make sure your public mobile account is active if you plan on porting your number out to another carrier!
sarahhaniya
Bless your soul. I'm locked out of my account and it's telling me to contact Public Mobile but lol who am I supposed to contact. I stopped my autopay and will stop using Public Mobile altogether. It's literally the worst.
ChuckYeah
I tried the password reset a couple of nights ago and it took almost 2 hours. Hopefully you got it by now.  Don't forget your junk mail folder, just in case.
RossN
@sarahhaniya hi unfotunately thats far to common around here you probably tried to many times now and will have to wait an hour then try using chrome in ingognito mode after you reboot your computer good luck
GinYVR
@sarahhaniyaThe password reset link can come late. If you need access to your account immediately (ie expiring etc).. I suggest access the voice menu via *611 in the mean time.
