11-25-2020 07:01 PM - edited 01-05-2022 04:15 PM
How do I get my calling history..can't get it and need it ASAP.. from April 1 to Aug 28
11-25-2020 09:33 PM
@Channz wrote:How do I get my calling history..can't get it and need it ASAP.. from April 1 to Aug 28
@Channz You can only get the last three months of your calling history by logging into your account and selecting View my Usage under My Plan/Change Plan on the overview page
I'm not sure if moderators will be able to given you a longer timeline of your calling history but it's worth asking just in case.
Did you try looking through your phone's call log? That should give a much longer calling history as suggested earlier. Even on an older phone without a SIM you can view your calling history by simply trying to make a call which doesn't connect but the call log will be available afterwards.
11-25-2020 07:11 PM
@Channz You can contact mods regarding this. Create a ticket by clicking on the chat option on the bottom right of the pages and follow the steps.
11-25-2020 07:04 PM - edited 11-25-2020 07:10 PM
Quickest way is check the phone app on your phone. I have calling history back to Sep 2019 on my Android 9 phone.
Create a moderator support ticket for help using the Chat button at the bottom right corner of this page. But it will take a couple of hours to 2 days.
