Reply
Legend
Anti-malware, junk file cleaner, and battery booster
Hello,
For the past year or so, I have been using 3 apps downloaded from the Google play store.
They are ad-supported freeware. The company is Cheetah Mobile, located at www.cmcm.com
The apps in question are:
1: Battery Doctor (Battery Saver)
2: Clean Master (Speed Booster)
3: CM Security Antivirus AppLock
There is no user guide that accompanies any of the above three, but enabling settings is simple to understand, and simpler to do.
I have found that both my Moto G phones run quickly, and never lag in everyday performance.
Good luck!
Re: Anti-malware, junk file cleaner, and battery booster
Is this relevant at the moment?
Thread is from 2015...to me not so much....
It seems that post itself is unsolicited spam?
Not sure of its relevancy or appropriateness.
Seeing as @Martin was a long time subscriber, and has obtained Legend status around here, I’m sure this post was nothing more than a helpful suggestion back in 2015.
Personal device maintenance and security is still a major concern for everyone.  It’s up to the end user to research and find tools that work for them, themself.
Fair enough.  I'm new to this neck of the woods—and respectively use an iPhone so 'security' hasn't been the biggest concern.  I also take other precautions as well in terms of what I access, using VPN for confidential or secure connections when necessary, and avoiding spam... seeing the 2015 post re-surface made me think "spam" but that is my over-cautious spiddy senses telling me not to download unsoliticited apps.  Was merely sending those concerns to the world... all the best.  Smiley Happy
