Reply
Account
I want to log in forgot my password
Re: Account
@Jrhaine08  - Try the forgot password link.  If you don't get the email within a half hour or so, use SIMon (question mark) to open a ticket.  Just type something like Forgot Password into SIMon, and follow the prompts to open a ticket.  Response time could be anywhere from a couple of hours to a few days.
Re: Account
Did you try the lost PWD link? It takes some time but I think it still works.
Check often as the code expires after 2hrs?
Otherwise, you'll need moderator help.
Check your junk mail folder too just in case.
Re: Account
