Reply
Account signup
I got a public mobile SIM card recently anf then an email was send for me for changing my accout password.
when I clicked on the link it says the link has been expired you should request another link.
How can I request another one?
It dosen let me to register an account and it says you should reset your password.
I lick on the forget password and it says the Email is not identified.
so how can access my account?
Re: Account signup
Give it an hour and retry then. Use in cognito mode.
Re: Account signup
If your absolutely sure you're using the correct email, with no typos, try again in an hour as @hairbag1 says.
Best to clear your cache before trying again and use incognito mode if possible.
One other thing, if you signed up at a kiosk, you may still have to create your self serve account.
Re: Account signup
@farzadabdollah Click here to register your selfserve account.
Re: Account signup
@farzadabdollahAre you sure the email requesting a password change is not a phishing email? A email that is designed to steal your credentials? That might explain the difference.
How did you sign up for your Public Mobile account? Did you ever have a selfserve account before (ie able to login via the top right hand corner?).
Re: Account signup
PMs website is a bit finicky. I faced some issues while registering too. Your best bet is waiting for 50 minutes, clearing the cache or trying a different browser
It should work
YVR
Re: Account signup
Please see below for a quoted tread from a Moderator Post.   Would suggest to contact the moderators and/or wait to log in till tomorrow morning.
System maintenance – On August 12 2019, 10:00 PM ET – August 13 2019, 8:00 AM ET
This means that between August 12 2019, 10:00 PM ET – August 13 2019, 8:00 AM ET you won't be able to do the following:
*Access your Self-Serve account
*Activate a new account
Re: Account signup
It is very likely that this could be the cause of the issue you are facing
I would recommend that you should wait till tomorrow morning. Optimistically hoping that it will work
Tags (1)
