Reply
Phoenix1
Account number
How do I get my account number? A family friend activated the phone and set up self serve. We no longer have contact with that friend.
Accepted Solutions
HALIMACS
Re: Account number
@Phoenix1
To contact a moderator, there are 2 methods: (you'll likely need to utilize #2 without account verification capabilities)
  1. Use the ticketing system for a faster response time. Click here and type moderator assistance, then select account-related issue, then select you need a human now.  Follow the prompts to submit a ticket,  or,
  2. Send a private message to the moderator by clicking here  You’ll need to be logged into your Community account for the link to work.
All Replies
z10user4
Re: Account number
It's embedded in the To: of the welcome email. Or if you can log in to your self-serve account, it's in the upper right.
Phoenix1
Re: Account number
I can’t log in and don’t have that welcome email
Re: Account number
@Phoenix1   If you can't logon , try using the Forget Password link and try all the possible email addresses you might have used.
If that still not work, you will have to open a ticket with Mod.
1. For faster response (2 to 48 hours), Click on the bubble in the lower right corner and request moderator assistance, or you can also use this direct link instead https://widget.telus.tiia.ai/publicmobile/publicmobile.html, then type "Submit a ticket", select Account-specific issue, then select I need a human now. Follow the prompts to submit a ticket.
2. Or you can Send a private message to the moderator here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Phoenix1
Re: Account number
How do I open a ticket
z10user4
Re: Account number
 @Phoenix1 : Then you'll need to contact the moderators. You'll need to provide many bits of identifying information. Click on the cartoon quote button in the lower right and muddle through the stupid chatbot. You'll either get to a submit ticket option or sending a private message.
HALIMACS
Re: Account number
@Phoenix1
RosieR
Re: Account number
Hi @Phoenix1 good luck
EDITED:  OP already chose accepted solution
RosieR
Re: Account number
@Phoenix1 if your friend activated the phone, do you know if they activated online or instore?
If in store, there may not have been a Self Serve account created.
Try to register for a Self Serve account here:  https://selfserve.publicmobile.ca/self-registration/
iamfernandan
Re: Account number
Thanks for the info.
