Account number
Mahinder1234
I need my account number mahinder chauhan
cavemantoronto
Is it needed  because you are porting out?  Is there an issue with Public Mobile that you haven't been able to fix?
Jackhyf63
@Mahinder1234 You will need to login to your self-serve account to get the account number. If you can't login, you will need to send a private message to the Moderator_Team with your account info.
Lieux
In a white rectangle and looks like 10000......
I need my account number xxxxxxxxxxxxx
If you can log in to your self-serve account then it's there in the upper right.
Edit: It's also in your activation welcome email if you still have it.
