Reply
pjhtyl
Account login
Hi
I’m account was xxxxxxxxxxx requested a change of email to xxxxxxxxxx. Now I’m not able to login in check usage. It indicated password wrong
please advise
edited by computergeek541: e-mail address removed
Accepted Solutions
Triguy
Re: Account login
Did you try the forgot password link ?  If you still assistance then submit a ticket to a moderator by clicking on the bubble on the bottom right corner.
All Replies
Re: Account login
Please go to  https://widget.telus.tiia.ai/publicmobile/publicmobile.html and type "change self serve e-mail" if you still need the change peformed.
Triguy
Re: Account login
Re: Account login
@pjhtyl wrote:
Hi
please advise
@pjhtyl , did you get a response that your email change request was complete? If not, maybe your old email is still the active one.
HALIMACS
Re: Account login
@pjhtyl
Just to confirm that you tried logging in with the new e-mail address that you requested it be changed to?
If that doesn't work (yet), perhaps the Mod's have not yet updated it?
Do you have any messages back from the Moderators to your Private Message box confirming the change was completed?  Check the envelope icon between your avatar and the bell symbol on upper right for any messages from the Mods.
