Account is locked
MuskokaBoy
7 REPLIES 7
Then contact a moderator @MuskokaBoy as @kselmak posted earlier.
@MuskokaBoy wrote:
I have tried the link but it is not being reset...it's been 24 hours.
Then contact them directly
MuskokaBoy
Thanks @MuskokaBoy . You could wait an hour, clear your browser history, go to incognito/ private mode and try to reset it again. If it continues, contact a moderator and explain your situation.  Click on the green questionmark in the white circle at the bottom right of your screen.  This connects to the autobot Simon . Type moderator and follow the prompts to get to one.
@MuskokaBoy wrote:
Says password was incorrect...and will not let me reset it.
kselmak
Can you wait for an hour and then reset password. Is your phone working?
If that didn't you can contact moderators https://publicmobile.ca.ada.support/chat/ be ready to prove you are the owner of the account
Alternative contact since you can't login https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
MuskokaBoy
gblackma
Why is it locked @MuskokaBoy . Did your autopay fail? We need more information.
