Reply
Highlighted
Account Locked Out
Hi,
I have tried to reset the password for Self-Serve but it ended up expiring by the time i received the email. I have put a ticket in and sent a private message to the moderator team but have yet to receieve a response. Can someone help me out please?
Highlighted
Re: Account Locked Out
Unfortunately regular users don't have the kind of authoritity to assist in this case - you'll have to wait for the moderator to respond.
Good luck!
Highlighted
Are you sure it's your password that you can't remember and not your email? Did you get locked out for an hour after a few tries?
Highlighted
I need to access my account. My account has been locked out since yesterday
I need to change my plan.Self serve is not working.
Highlighted
All good problem solved, the password reset email seems to be significantly delayed and a very short window to use it. Very odd for a password reset tool never experienced that before.
Highlighted
My problem of being locked out is not solved.
Highlighted
Try again in an hour. Clear your cache files, use incognito mode and also try a different web browser. FireFox seems to work pretty good.
Alternatively, click the ? in lower right side of screen to start process of moderator assistance.
