Reply
4215
Hey, I recieved a notification to install a new voice mail. It was asking for a 4215 number. What should I enter for a 4215 number?
Re: 4215
Setting up voicemail.
Hold down the ‘1’ key on your phone keypad to dial your voicemail access number. Calling your own 10-digit phone number will also bring you to your voicemail.
  1. When prompted, enter a password between 4 to 15 digits long. Try to make it hard to guess, but easy to remember. It will be more secure if you avoid using numbers that are repetitive or sequential such as ‘1111’ or ‘1234’.
  2. Choose whether you want to bypass your password when calling from your own phone.
  3. Record your name, and a personalized greeting.
  4. When you’re done, hang up to end the call.
Re: 4215
Install a new voice mail?  You you can recieve and check it without need to install any separate app.   What is a 4215 number?
Re: 4215
it should say  4 to 15 character  as your PIN
Re: 4215
I would highly doubt the company would send a message asking for a code in a short-form manner like that. I would suspect this is spam/phishing.
Re: 4215
Thanks so much for the advice!
