32 days of no service
alli_b
I ported over from Virgin Mobile last month and have found myself with the infamous no-service issue - no calls / no texts / no data / etc. The phone doesn't seem the recognize the sim card at all (and doesn't work in other phones either) and I've tried many fixes mentioned on this forum. About the only thing that works is trying to call the phone, which gives an answering machine that I obv can't access. I called Virgin Mobile and they said that the port was completed and the issue is now with Public Mobile.
I've now waited over a month for resolution. After sending my initial support request, I've had people from PM answer back asking about my issue, replied to them, and then... nothing. I like to think I've been patient, but to see others get resolution within days while I've been waiting for over a month is frustrating.
13 REPLIES 13
CS_Agent
Customer Support Agent
@250-9719471, I'm sorry to read about your port issue. Please check your inbox, I just sent you a private message.
Thank you!
Aïssata
srlawren
@mimmo to the word (including the macro we authored together about contacting the mods), that's exactly the reply I would have left had you not bested me by 5 solid hours.  Well played, sir.  Well played.
mimmo
@250-9719471  usually best to stary your own thread and not use your tel number as a username.  anyway you have a stuck port and you need to send some infor to the mods follow the instructions below.
How can you get help with your account, activation, or service?
In your message please include:
  • PM Phone Number, 4 digit PIN, Account email address, Detailed explanation of your issue
If you have a Porting issue, please also include:
  • The number you want to port, PM sim number, old account number, old account name exacly as on bill
Don't know your pin?--provide any 3 of the following:
  • Complete mailing address, Email address, Alternate phone number, Date of birth, Last top up date & amount
How long until they reply?:
  • Office Hours: Mon-Fri 9am to 9pm, and Sat-Sun 9am to 7:30pm [Totonto Time] from 9am to 7:30pm [Totonto Time].
  • Messages are replied to during business hours and in the order they are received
  • Typical response time is between 1-3 hours, depending on message queue, but can be up to 48 hours.
  • There is no need to send multiple messages.
Additional Useful Information:
  • Search PM-GUIDE (remove "-" during the search) to find some informative posts and answers to many common questions about Public Mobile
250-9719471
Ported over my number from Virgin 30 hours ago. Anyone who phones me gets my old Virgin answering service. I can not receive texts or calls. I can call out for some reason...my number is xxx.xxx.xxxx
250-9719471
I ported over from Virgin about 30 hours ago. I can not receive calls or texts. However I can call out...anyone who calls my number gets my old Virgin answering service.
alli_b
Hi everyone,
Shazia sent me a replacement sim card and everything works great now.
Thanks for the support.
@alli_b With Shazia looking into your problems you should be on the way to resolution, but if still stranded tomorrow let us know.
Vickel
I would say its the SIM or some issue during the porting process if you have tried on multiple phones.
Shazia_K is looking into it now. You are in good hands.
Good Luck!
alli_b
The phone is definitely unlocked.
As for error messages I only see "No Service" at the top. The About Phone page shows the following:
My phone number: Unknown
Network: Unknown
Mobile network type: Unknown
Service state: Out of service
Mobile network state: Disconnected
EDIT: Sim card # sent
Shazia_K
Retraité / Retired
Retraité / Retired
Hey @alli_b
I'm sorry for the delay in responding back to you as you might already know we are currently receiving a higher volume of requests than our usual.
Can you please send me a private message with your Public Mobile SIM card #?
Thanks,
Shazia
ShawnC13
@Shazia_K  are you still around and able to look at this for this member.  Seems like a very long time with no service.  Thanks in advance
Is there any error when entering the SIM?  Your phone is unlocked correct?
MoreYummy
It is long enough indeed.
Is your phone unlock and workable at public mobile, its best to start from testing using another public mobile user?
What does it say when you put in your sim card on your screen, and are you able to go to the network serach section and find any network at all?
If you already tried many solution, then only way to fix it is contact mod.  @Shazia_K
will13am
Send a PM to a moderator.  They are all online at the moment.  They should be able to take care of your problem fairly quickly.
