02-02-2020 06:48 PM - edited 01-05-2022 09:18 AM
I am on the $60 plan that included 2GB US Data and calling, and see the US portion is no longer listed on my summary page.
I'm on autopay program.
Any ideas?
02-03-2020 12:23 AM
@iulianca wrote:SOOOOOOOOOOOO
FINALLY!!!!!!!!!!
Moderator confirmed me,on my account:
1GB Add-on ------------------------- 1866.319 / 2048MB means 2GB US data practical finished.Sorry if I did you spending your time for nothing.
@iulianca Not at all thats what were here for....and you helped us by confirming how the US 2gb roaming plan data is now displayed in accounts with that plan. It's a win win all the way around. We're always happy to help. Drop by anytime you need us.
02-03-2020 12:10 AM
So it seems kinda confusing to me. There were posts back in the $60 thread that indicated that the line was called:
2GB at 3G Speed.
I don't know why you're seeing 2048 in a 1gb line but stranger things happen around here.
02-02-2020 11:33 PM
SOOOOOOOOOOOO
FINALLY!!!!!!!!!!
02-02-2020 11:32 PM
@gblackma wrote:@darlicious , @iulianca is on the grandfathered $60 vacation US/Canada plan with the 2gig US roaming. Which it seems has changed in her plan area.
@darlicious wrote:@iulianca Remember the US roaming add ons start immeadiately after purchase. You can add funds to your account and wait until you are almost completely out of plan data before submitting payment and actually purchasing the add on. You are close to running out.....the 10 day time clock starts at the minute you purchase it and runs out ten days to that time....or once you deplete it. If you require another add on it is advisable to add the funds to your account and contact a moderator and arrange the approximate time you will need to have the next add on added to your account by the moderator. This will help avoid the 24 hour wait time required for you to make the purchase.
1GB Add-on | 1866.319 / 2048MB |
Although completely mislabeled this is the usage of the US 2gb roaming plan data. The OP is running out of data with less than 200mb left. Thus my advice about purchasing a US roaming data add on.
02-02-2020 10:28 PM
It would be more accurately described as a 240 hour, add on. 🙂
It is similar when purchasing roam mobility plans, if you pick the start time sometime in the middle of the day you can kindasorta get 2 usable days out of 1 purchased, depeding on your arrival/departure times...
02-02-2020 10:28 PM
02-02-2020 10:20 PM
02-02-2020 10:05 PM - edited 02-02-2020 10:11 PM
@iulianca You should be able to use your 2gb US data. Be sure to reboot by your phone after enabling your roaming. You may need to manually select either at&t or T-Mobile for a better connection. When this plan was eliminated the US features were no longer listed under your plan details but still available to you. Presumably the features will appear in your account once enabled in order to be able to track usage.
I see now you can see your US data just appears different from before. If rebooting your phone does not restore your internet connection try using airplane mode. Turn on for 5 min. Turn off. This should reset your connection. You should not have to buy an add on unless you deplete your US plan data.
02-02-2020 09:08 PM
I recall this discussion back when the plan was available. Since there are two categories of plan data I don't believe it ever showed up properly, it just worked. This plan couldn't have been available for selection for any more than two months, likely less.
AE_Collector
02-02-2020 08:25 PM
My 1GB PM's holiday gift is not touched yet.
Yes,I'm in US now and gonna buy some US data
02-02-2020 08:19 PM
@iulianca it shows a 2gb but is called a 1 gig add on. Isn't the 2 gigs supposed to be US roaming ?
@iulianca wrote:You have absolutelly right, 2GB US data is missing from the plan details.
Instead I have:
1GB Add-on 1866.319 / 2048MBIt looks like some rest from 2GB,but no internet connection...and who is this 1GB Add-on,and where is 2GB US like before?
02-02-2020 08:15 PM - edited 02-02-2020 08:15 PM
Instead I have:
Is the 1GB add-on either the PM's holiday gift or the earlier PM's summer 1GB add-on gift. If you have used up your US data, then your only option is to buy the US roaming data for 10 days. Unless you can wait for your renewal cycle? Also are you in the US currently?
02-02-2020 08:10 PM
Instead I have:
02-02-2020 08:01 PM
@Nezgar wrote:Unless you used up the 2GB in the current cycle? In which case the line item will dissapear from the overview page.
That is possible too, but I remember reading other posters also saying that 2GB US data was missing from the plan details on the US/Canada $60 plan. Of course, I don't know if that was fixed and all the details are properly displayed now or not.
02-02-2020 07:55 PM
02-02-2020 07:32 PM
02-02-2020 07:30 PM - edited 02-02-2020 07:32 PM
Hi iulianca,
You can check the usage from your self serve account.
Kind regards,
Alex
02-02-2020 07:21 PM
If I have access to that 2 GB US data,how can I see my usage ?
02-02-2020 06:52 PM
@iulianca wrote:I am on the $60 plan that included 2GB US Data and calling, and see the US portion is no longer listed on my summary page.
Any ideas?
Long as you haven't changed or altered your plan...you still have access to that US data/calling whenever you're in US.
That covetted old plan is no longer available at PM...so if you change it, you won't be able to get it back again.
02-02-2020 06:52 PM
@iulianca Contact a moderator and explain your situation. Click on the green questionmark in the white circle at the bottom right of your screen. This connects to the autobot Simon . Type moderator and follow the prompts to get to one (CLICK on account specific question and human and submit a ticket)
Any ideas?
02-02-2020 06:51 PM
Since your question is account specific, you should contact a moderator who can check your accouont. Just click on the question mark at the bottom of the page and type in Moderator, specific account question.
