08-29-2019 09:54 PM - edited 01-05-2022 08:43 AM
I wonder if there is a way to indicate whether the user name has already been taken while filling out the registration. I had to go back and fillin my password multuiple times before I was successful - just a suggestion 🙂
08-29-2019 10:20 PM
When you enter the name (i.e. chuck_grady) in the search it will search it as a word or a similar word. Then, type the username in again, and any further usernames you want to check and click "USERS" to search.
08-29-2019 10:15 PM
When I registered for community, the system mentioned if the username was taken while I was filling it.
08-29-2019 10:10 PM
Probably not too difficult but definitely not priority. Not very likely to pop up any time soon. Sorry
08-29-2019 10:06 PM
@CLG123 There is a way. Search something using the top search bar. Under Author filter, enter the username you want. If it comes up, then it's taken.
