11-14-2019 09:06 AM - edited 01-05-2022 09:43 AM
new to site. Can anyone help with creating a ticket for missing rewards.
11-14-2019 11:57 AM
Any complicated issue should be sent to a moderator by clicking on ?, bottom right, and following instructions. This issue is fairly common.
11-14-2019 10:30 AM
11-14-2019 10:24 AM
@Mollie, the moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.
11-14-2019 09:07 AM
Click on the question mark on the bottom right to submit a ticket.
